Will It Fit In My Garage? (2 Viewers)
Sixgun95
209
111
AZ
25' Overtrail, considering the Westcott Level Kit and 35" tires. The roof has the roof rails that run down each side, ones that came on the truck. Will the truck fit in a standard 84" tall garage door entry?
I am also on OME 2.5” lift and 34” tires and measured 6’-7” (79”) to the top off my westcott rack (same as top of shark antenna).
It should fit through an 84” clear opening. Also verify your actual garage door clearance since some doors/equipment hang lower than the actual garage opening
    Votes: 8 80.0%
    Votes: 1 10.0%
    Votes: 1 10.0%
