🛠️ Member Build Hello from Vegas! (1 Viewer)
�Member Build
LVGXOT+
8
6
LAS VEGAS
Hi! This is my first time posting here and I wanted to thank everyone in the forum for all of the valuable information! It took us about 8 months to get this rig and Im so looking forward to rocking it!!
25 OT+ Earth and black / Chateau NuLux
Here is mods so far…
Full X Pel PPF in satin finish.
25% X Pel tint through out and 50% windshield.
Landbully sequential side mirror lights, hatch light and Fuel & Fire apple iPhone mega safe charger mount.
Wescott Design Roof rack
Kings 2.5 with camburg Kinetk Billet Uniball UCA and Eibach spring in rear.
TOYO AT3 35x12.5x17 Load C
Nytop wheels, bumper, rock slider, full skid plates, and front / rear recovery point.
Baja design XL linkable light bar and S2 pro lights.
Ikamper DLX.
More to come… lol
Thanks! I appreciate all your help btw. What’s your setting on the kings? I set mine to the softest for now.
Always here to help. I set mine at 15 clicks from soft for daily driving. You can tinker a bit to dial in what’s most comfortable for you.
I would use the softest setting on washboarded roads only. That with airing down to 20 psi will yield the most optimal ride quality on corrugated roads.
How was the ride home with the Kings and larger tires? Did you use hub rings?
Bit stiffer and bit louder vs stock, yes used nytop hub rings and I was getting 285 miles with full tank.
Bit stiffer and louder vs stock, yes used nytop hub rings and I was getting 285 miles with full tank.
Sounds about right. No way around the constant humming sound from those giant tires.
You won’t see any higher than 285 now that your vehicle is heavier and have much more rolling resistance.
Prob less now with Rtt. 😔
  • "SL"
    Votes: 17 60.7%
  • "C"
    Votes: 4 14.3%
  • "E"
    Votes: 7 25.0%
