If you have installed a light bar on the roof rack - would be interested to see how you wired. Are you running power to the rear hatch and drawing it from there? If so, how did you connect so you cant see the wires?
Prinsu roof rack. Light bar on front of rack. Ran power down driver side windshield (outside) to driver side Aux 1-2 connector. Slot under windshield molding running down windshield at the A Pillar was plenty deep for wiring. I just squeezed a bead of Black RV silicon sealant in slot then pushed wire in. At the bottom of the windshield route wire under the cowling. The only wire visible is a very short piece at the top of the windshield where it enters the molding. Put a few thousand miles since install and all looks good.If you have installed a light bar on the roof rack - would be interested to see how you wired. Are you running power to the rear hatch and drawing it from there? If so, how did you connect so you cant see the wires?
