Lutz Auto Lexus GX550 (2024+) Speedometer Calibrator
ctechauto
Texas
Just installed the Lutz Auto speedo calibrator on my shop truck '24 OT+. I am not affiliated with Lutz in any way; purchased this personally.
Lutz Auto link: 2024+ Lexus GX550 Speedometer Calibrator | Lutz Auto
Went from stock sized 265/70/18 to true 35x12.5x18 with an approximately 7% difference in rolling diameter. That threw off the speedometer, odometer, and fuel economy/MPG gauge. It is a PnP device, very easy to install. Took about 30 minutes end-to-end and 20-25 minutes of that was removing and replacing interior panels, glovebox, airbag etc.
I went a little conservative on the calibration and did 6% adjustment and it's actually bang on validated by Waze/GPS. Speedo, odometer, HUD all work as expected. Cruise control (normal and adaptive) still work, but the cluster (and HUD) will show the uncorrected (stock) speed, but this is explicitly already called out on their website.
It's not permanent, can be removed if you want to go back to stock and all it does is just intercept the CAN signal(s) and outputs the new/calibrated number.
Highly recommend if you've moved up tire sizes. And if you're in the DFW area, I can provide and install this for you at my shop.
