Skid plate issues (1 Viewer)
rocksallday
california
Maybe I'm overthinking this, but I really can't seem to land on a 'good' skid plate setup for the GX.
Background - I offroad. I'm bad at it. I need good protection.
Here's what I got so far-
I had the OEM skid plates on my OT+.
Test #1: Rival transfer case + OEM front & center.
I added the Rival transfer case skid before heading to my first trip, because it was the only one I found that could be added to the OEM set and was reasonably priced.
I hated the way it bolts to the frame, but I did it anyway. Because there are no frame blind nuts for a transmission skid plate, every manufacturer seems to come up with their own weird solution. In the case of Rival it was a small piece of metal with threading you stick into a frame hole, and try to get the bolts to go in without spinning the metal too much. The metal is thin and breaks easily.
If anyone ever tries to remove the skid plate, that metal will be lost inside your frame rattling forever and no way to reinstall the skid.
Also, the rear part of the skid plate hangs really low and makes for really bad clearance. As if the GX isn't already pretty bad in terms of clearance.
Test #2: Nutserts for the Rival skid plate + OEM front & center.
I replaced the weird nuts Rival provided with Nutserts.
It works, no more pieces of metal that can get lost.
However... it turns out nutsers are not so great for vibration / impact applications. They might loosen over time.
Anyway, took the car on an easy trail. Bent the OEM front plate beyond recognition.
The OEM plates are so thin that when I landed on a rock, it bent the front skid all the way to the front diff. It wasn't even a big rock, it was more about the very soft suspension letting it bottom out into that rock.
Test #3: CBI full skid plates
Looks good, solid build, better clearance than stock and/or Rival, only one weird blind nut on the transfer case skid.
However... the bolts for the transfer case skid are impossible to get to. Maybe if you have some specialty tools or really thin arms. I managed to tighten them a bit before realizing that there's no way in hell anyone will ever be able to un-tighten them and my hand might get stuck there forever. There's just no way to get your hand in there.
Not a big concern except that you have to remove the transfer case skid plate to grease the driveshafts, which in theory means it needs to be removed every 5K-10K miles.
Ended up throwing away the transfer case skid.
Took the car to an OHV area to test the suspension. Guess what- e-KDSS hits the front skid when fully articulated.
CBI told me they're looking at redesigning the front skid for better clearance on the e-KDSS.
idk how other skids are, but at this point, I'll probably stick with CBI, discard the transfer case skid (transfer case looks robust enough :) ) unless I come up with a better solution on how to bolt it to the frame that's easy to unbolt, and cut the front skid for better clearance of the e-KDSS system.
I have the Slee system. It seems to be the most comprehensive to me and protectects the Catalytic Converter. It has a separate drain cover for draining the oil but you still have to remove a panel to get to the Filter. All in all I'm pretty satisfied with it. I got the steel plates which give you good protection but they are a good deal heavier than the OEM.
How's the rear / transfer case skid? Easy to remove to access the driveshafts?
And how's the clearance for the center skid? Better than the OEM design?
I have the stock OT front skid and I installed the NYTOP transmission/catalytic converter skid. It provides better protection than the stock center skid.
NYTOP Catalytic Skid
Here's a comparison of NYTOP (left) vs. stock:
NYTOP also sells a set of 3 skid plates which look like they provide pretty good coverage:
NYTOP 3 Skid Package
I've hit my front skid a few times but only scraped, never really dented or damaged it.
There's really no difference in clearance to speak of over the OEM plates, although Slee says there is in that the plates have a smaller gap is some places. Since I have the steel and not the aluminum plates I would say they would be harder to remove and install simply because of the weight.
I have been considering Slee's steel skid plates for a while. I live downtown San Diego and don't have access to a garage or driveway. Would you say this can be installed by one person in a parking lot?
Not the kind of install I would want to do. You would need two rolling jacks. one to give you clearance and the other to hold the plates while you bolt them on. I don't know what you would do for lighting in a parking lot. Just doesn't sound to appealing to me.
What I would suggest is doing it through the Truck Shop on Mira Mesa. They will cut you a break on the purchase price which could make up some of the labor cost to install. They saved me a couple hundred on the parts which covered some of my labor cost and I got a professional install.
I dunno about Slee, but I did watch their video and nothing seemed particularly difficult compared to the CBI and OEM skids. They're all the same. Only thing I suggest is either get a ramp or a few pieces of 2x4 you can drive on to get the car a few inches off the ground. I'm sure floor jacks would work too, but you'll be working under the whole car, bolting things to the frame, it's easier to just park on something that gives you more clearance.
The one thing I will say about Slee in particular, is it seems to me they've connected the rear and center pieces to a single larger piece, which may be a bit heavier to work with as you're laying on your back under the car, but should be doable.
edit: I did the OEM, Rival and CBI installs in my driveway.
Given my situation, I figured the steel version might be a little difficult for one person, but thought I'd ask.
Thanks for the Truck Stop recommendation! I drove a Chevy Cobalt for 20 years until this past January so a lot of this is new to me. This forum has been so informative and I appreciate your reply.
Good luck. I’m learning as I go as well so don’t hesitate to ask for help. That’s what this forum is for.
Just had a call with CBI and I'm beyond shocked.
I have the CBI skid plates and as I mentioned earlier, the KDSS system touches the skid at full articulation.
After some back and forth the response I got was-
"Our engineers tested the skid plates on our in-house GX550 and found no issues when the suspension is compressed, but are now working on a revised design to guarantee clearance when the suspension is fully decompressed".
It's like "our skid plates are great for on-road, but you might run into issues off-road"? wth?
I guess the good news is they're "working on a fix" (although it's been a while since I opened this ticket).
I can recommend Slee's skids. Finally happy to say I have tested them (a few bumps, dents and scratches) and had them off and on myself on the driveway. Not too heavy or difficult for this old man, just slide under there and do it. (better with a lift or drive onto some 2x6s).
Slee puts years of real off-road experience and actual field testing into the design so you won't be disappointed. I don't know about the others.
Just my opinion, and honestly I'm speaking to myself, but if you run trails tough enough to need heavier after market skid plates (the stock skids are really pretty good) then practicing sliding under the car, to install skids so you know how they attach and what tools you need and where the strengths/weakness are, is well worth it. It's much easier on the driveway than in a boulder field or mud pit. I'm not the only one who changes tires, oil, brakes, fluids or grease fittings on the driveway am I? I do like the scenery better on the trail but the driveway is better, especially for the first time. ;)
Victory 4x4. They have aluminum and steel plates. No nuts inside the frame. Great fit and protection. Sounds like I was paid to say that but, just a happy customer. Only thing I had a problem with was squeaking. I put rubber padding in strategic places and it's all good.
I got a question for a front skid plate. I have the Millercat catalytic converter shield but need an idea for the front skid plate. What would work best for my set up. I have a Premium plus.
