2024+ Lexus GX550 Reverse Lights - More Visibility After Dark
MandRautomotive
📦 Supporting Vendor
Burbank, CA
2024+ Lexus GX550 Reverse Light Upgrade
For anyone with a 2024+ Lexus GX550 looking to improve visibility when backing up at night, we have a reverse light kit that adds two 20W PRO pods to the rear of the vehicle.
The pods use a flood beam pattern, giving you a wider spread of light around the back rather than just a narrow beam straight behind you. They mount with metal brackets using a bolt-on setup, so there’s no cutting or drilling required.
You can choose between amber or red backlighting. The amber can be wired as a turn signal, while the red can be wired as a turn signal or brake light.
More info here: https://mandronline.com/products/2024-lexus-gx550-reverse-light
Installation Guide:
lexus-gx550-reverse-light-kit-amber-red-backlight-pair-2024-2026-wide-beam-off-road-trail-vis...webp
For anyone still looking into reverse lighting for the GX550, here's another look at this setup. The two 20W PRO pods add a wider spread of light behind the vehicle, which can make a real difference when backing up at night.
The bolt-on brackets keep installation simple, with no cutting or drilling needed. You can also choose amber or red backlighting depending on how you want to wire it.
More details here:
Feel free to reach out if you have any questions!Lexus-GX550-Reverse-Light-Kit-2024-2026-Amber-Red-Backlight-Pair-Pods-Flood-Beam-Lighting-Lex...webp
More details here:
Feel free to reach out if you have any questions!View attachment 25213
I have those on my GX - like having the sun back there. Outstanding!
