Hey everyone,
If you are looking to optimize the trunk space in your Lexus GX for overland trips or demanding trail adventures, we have engineered a complete transformation for your cargo area.
Wheels Feels storage and advanced camping system is designed using advanced 3D scanning technology and test-fitted on real vehicles for millimeter precision, ensuring a perfect, flush fit inside the Lexus GX470, GX460, and the GX550 platforms.
We know utility matters. The entire system mounts securely to your Lexus's factory anchor points using just 4 bolts. No drilling into metal, no turnbuckles, and no sketchy brackets are required. If you ever need to utilize your third-row seating, the entire unit can be completely removed in under 5 minutes.
To turn your GX into a fully functional mobile basecamp, you can add our integrated kitchen module. It seamlessly slides out to provide stable working tables and comes equipped with an automatic faucet and sink setup.
Whether you are packing for a quick weekend trek or a long-haul overland expedition, this heavy-duty setup maximizes cargo space, keeps tools organized, and eliminates trail rattles completely.
Made in the USA. Lifetime warranty.
Smart Engineering & Tough Core
- Eliminates Seat Slope: The system’s height ranges from 8.3" in the front to 5.7" in the rear. This variation completely eliminates the factory slope you get when the rear seats are folded, providing you with a perfectly level, flat cargo floor for gear or sleeping setups.
- Rugged Materials: The core structure is built from varnished, waterproof plywood that handles spills, mud, and heavy trail use without structural degradation.
- Finish Options: You can choose a soft-touch carpet finish for a clean, factory-level look and a quiet, rattle-free ride on corrugated roads, or opt for a sleek beige varnish covering. All drawer interiors come varnished, with an option to add soft carpet lining.
No-Drill, 5-Minute Installation
We know utility matters. The entire system mounts securely to your Lexus's factory anchor points using just 4 bolts. No drilling into metal, no turnbuckles, and no sketchy brackets are required. If you ever need to utilize your third-row seating, the entire unit can be completely removed in under 5 minutes.To turn your GX into a fully functional mobile basecamp, you can add our integrated kitchen module. It seamlessly slides out to provide stable working tables and comes equipped with an automatic faucet and sink setup.
