- Thread starter
- #41
oh...I understand where you drilled now. You added more weep holes on the underside..lolThe bottom of the Hood, didn’t effect the top!
The screw plugs fit the entirety of the 2 rectangular shaped openings in the center brackets. If you press them in fully, they won’t spin and will make screwing it in that much easierGot my Deflector from @munkeeboi today, smooth, great transaction and am happy with it! I don't often do posts with pics etc. but thought I would try on this one.
Install notes:
1. Instructions are pretty clear, just be patient and read them fully and then follow them
2. TAKE YOUR TIME with lining everything up and making sure the "Fixed Clip" line up with holes (2) on underside of hood
a. I tried to work from right to left and as I progressed the line up changed and I had to re-work it...not fun, these clips are tight!
3. Don't be afraid to use a small rubber mallet, I used a small screwdriver to spread the clip and tap with mallet to get them started.
4. I don't like the "Screw Plugs" for the "Fixed Clips" and will probably do something different, but even without them the deflector is solid
a. This might just be me and nobody else will have a problem, but getting the "Screw Plugs" in the " Fixed Clips" and keeping them from spinning while trying to screw them in was something I ran out of patience for tonight.
5. You can see from the pics that the only "touch" on the vehicle is at the attachment points that are protected by the included "Anti Abrasive Tape" which is basically a very rugged 3M clear PPF
6. I have had very similar type deflectors on many vehicles before and while I can't quantify it, I feel strongly they have decreased bugs, rocks, etc. on the hood and windshield.
7. I think it looks awesome on my color combination!
Cheers! and good luck everyone!
Before you add the two center clips to the deflector, hold it up to the hood and prefit the clips to make sure the opening is or will be closest to the hood when mounted. I reversed them and the clips were about a half inch away from the hood. Once I mounted the deflector, I didn’t want to break it trying to get it off, so I drilled a couple of small holes and put a couple of big washers on them which did the job.Anybody from GB1 volunteer to take pics showing the correct orientation of said clips so us lowly GB2 peeps don't reverse the brackets and end up drilling holes in our hoods?![]()
hmmmmm.....That clip orientation in your photo looks correct to me. The plastic portion of the deflector shouldn't be going under the hood lip. Look at image 9419 and 9421 that I posted above. The part I circled in your photo should be the portion that goes around the leading hood edge.Before you add the two center clips to the deflector, hold it up to the hood and prefit the clips to make sure the opening is or will be closest to the hood when mounted. I reversed them and the clips were about a half inch away from the hood. Once I mounted the deflector, I didn’t want to break it trying to get it off, so I drilled a couple of small holes and put a couple of big washers on them which did the job.
When I put the deflector on, I had at least a half of an inch between the bottom of the hood and the clip; that's why I figured I had them reversed because there was no way the hardware the came with would work with those gaps so, as I said, I improvised and it worked.hmmmmm.....That clip orientation in your photo looks correct to me. The plastic portion of the deflector shouldn't be going under the hood lip. Look at image 9419 and 9421 that I posted above. The part I circled in your photo should be the portion that goes around the leading hood edge.
The plastic being wedged between your hood and grill, might cause some uneccessary stress at the center mounting points.
I'll put you on a list....not sure when/if it'll happen.Commenting in case someone backs out of their Deflector or a GB3 happens. Would really like one for my Overtrail I just picked up.
TYSM!I'll put you on a list....not sure when/if it'll happen.
