2024 OT. I have all the extra's (concierge, s-flow, eco) turned off. However, even when the temp control is turned down to 60 the vents continue to blow very warm if not hot air. This happens in the auto or the manual mode, and even when the fan is turned "off" in the manual mode. Frustrating because especially in 30 or 40 degree outside weather, the cabin gets too warm for my comfort so I find myself having to open the windows a crack to keep from sweating. When I turn the temp control down below 60, it goes into "LO" mode and the AC kicks on which is kind of a waste when the outside temp is so cold. All of this is with the "sync" activated.
Oddly, I was on a long road trip this weekend and I was struggling with the temp. Then all of the sudden at 60/61/62 degree setting, the air coming out of the vents was actually comfortable and felt considerably cooler then the air at the vents compared to when I moved the dial incrementally to higher temps. And I actually set the temp to 64 or 65 to feel comfortable for the remainder of the several hour trip. I was fooled into thinking that the heat issue had solved itself. Not so. Next trip it was blowing uncomfortably warm at the lowest setting once again.
I don't know what the variable is for why the temp setting actually worked on that occasion and generally does not work most other times--duration of driving, outside temperature, air quality/humidity. Admittedly I was fooling around with the setting and maybe accidently stumbled upon the secret code to get it to work, but I can't reproduce it now.
Anyone else experience the problem of heat too hot even on low temp settings?
