Good morning, Good afternoon, Good evening!
My garage door wasn’t raised completely and caught the shark fin antenna on my 2025 GX550 Overtrail+ as I drove underneath. I have a garage-door technician coming to rewind the cables and correct the door issue.
The impact lifted the antenna cover approx. halfway off. I pushed it back into place, but it lifts slightly if I gently pull upward. I also found two tiny broken pieces from the retaining tabs, approx. 1 mm each. I’m concerned about moisture getting underneath the cover.
I’ve already ordered the black OEM antenna cover kit, part number 86077-48060-C1. From what I understand, replacing it may require lowering the rear headliner and unbolting the complete antenna assembly from inside the vehicle.
Has anyone actually replaced this cover or removed the antenna assembly on a GX550?
Any firsthand experience, photos, or service-manual instructions would be greatly appreciated. Thanks!
