You are correct. It always falls back on "You get what you pay for". I was very skeptical about it at first but I guess I am comparing this also to a $3k proper tune on my other cars. The parameters taking into account for adding power will not be the same by just using a Map and TMap sensor like the Scorcher unit.sorry to see the issue you've had. Don't have a lot of sympathy though. You said you're an engineer. You of all people should know then, the millions of dollars these car companies put into the R&D. Cold air intakes and map tweakers are mostly hype. Maps are generic and mostly add fuel and air. Yes, there are oem parameters that could use refining but, a plug and play map tweaker IS NOT the way to do it. If you know anything about EFI live, you know what I mean.
AFE is a very large company that really doesn't care about you personally. You are one of thousands. It's unfortunate but, the way a lot of companies are.
I came very close to unplugging it one day and gave aFe the extra benefit of doubt that they will come up with a resolution quickly ... These are just cut and paste products. I'm not sure why they can't just release the dyno numbers on the Sport and Sport+ modes.Sorry about hearing about your problems, but it comes with the territory with car modding. The moment you put aftermarket mods on it, you have no one to blame for any issues caused but yourself. Sucks that parts companies can't all stand behind their product, but their goal is moving the product and hoping that at least 50% of the people are happy with it.
Sounds like the Scorcher is the issue and not sure why you won't just uninstall the Scorcher because it seems like you were raving about the air filter set in your other posts.
I've had zero issues with my AFE intake.
BTW, the scorcher is not a tune and should not be compared to one. It's a bypass that tricks your ECU. If you want a real tune, check out VFTuner. Their transmission tune is pretty darn good as well
Have you removed this from your vehicle - as in tossed in the trash, or are you still trying to fix it?I came very close to unplugging it one day and gave aFe the extra benefit of doubt that they will come up with a resolution quickly ... These are just cut and paste products. I'm not sure why they can't just release the dyno numbers on the Sport and Sport+ modes.
The intake and turbo inlet are good mods. They sound amazing is the main thing. My M3 doesn't sound that good spooling up.
I definitely will look into the VFTuner. Does the transmission update eliminate any of the hard shifts? We drive the truck aggressively and I found that it does not do it as much after it learns your driving habits.
Not yet, want to pick up a second hand unit?Have you removed this from your vehicle - as in tossed in the trash, or are you still trying to fix it?
The reason why I didn't want to go with VFTuner is to have a flash count. I have other cars that I flashed within a year but just was hesitant with the truck.The VFTuner tune costs just as much as the Scorcher unit. I have not had any transmission issues after the tune. There is a thread if you search for it.
Not sure what you mean by aggressive driving. Are you granny shiftin' and not double clutchin' like you should?
This could have been solved by removing the unit and ending your consumer relationship with them. There are many products out there but it seems like you want to make this AFE thing work despite all the downsides you have experienced. You have proven that they don't have to release dyno charts for people to buy this.
I just find it funny you started with "this isn't meant to bash anyone or give negative publicity" and then proceed to bash and post negative feedback for all to see. Not a personal attack on you by any means, but calling out the humor as I see it.
I think the information you are proving is great. If anything, people benefit if the know after sales support sucks. Maybe I’m just old school - but adding in after market items to enhance engine performance and risk having Lexus tell a customer to take a hike/warranty is void seems beyond not worth it.Not yet, want to pick up a second hand unit?
Aggressive as in daily heavy foot driving and high speed highway use with the boost fully on.
Well it was my personal experience that I am sharing. My video isn't going to cause a Stop Sale of their products. It's only to share with the community on what I experienced. My expectations were probably way too high. That is the problem when you drive properly tuned cars and try to replicate that experience in a daily driver.
In my experience, you'd be better off not trying to install any kind of tune. I've deal with tuning for years on diesel trucks. My truck was a little over 1000hp. It's a very fine line to get it perfect. Most of the time, there's a problem. It takes a lot of logging to get it right.Very well said! At the end of the day ... nothing beats OEM setup for its range of applications and longevity. Once you start messing with things, including a proper tuned vehicle you are diminishing one category or another.
I'm reading up on the VFTuner and will most likely make the switch to that or run just the intakes only.
Good news - glad you were finally able to talk to themSome people like myself ... always want to squeeze a little more out of their vehicle. I understand it will never be perfect and this is probably why factory tuning is so conservative.
I am happy to report that I did get a call from aFe's VP and one of there technical developers. We had a good conversation and they truly recognize the issues I experienced. I took the Scorcher blue unit off and sent it back for a refund. They offered to make it right again once a solution is developed.
