Click the icon that looks like the Avengers logo to turn off the low speed camera assistAnyone know how to turn off the front camara when just stopping at red lights or stop signs? And is it possible to not have the mirrors aim down when backing up?
I don't know if there's a better way to do this, but when in reverse, I simply readjusted the driver's mirror up to be close to my normal position and it remembers. Now in reverse, only the passenger mirror moves - even after adjusting my normal mirror position in drive.I was trying to figure out the same on mirror. I only need passenger side mirror down, but not driver side. For camera, if you don't engage camera view, it shouldn't be on at all. If you turn it on, it will be on at low speed or at full stop and turn off with higher speed. I suspect you have camera view turned on.
That makes total sense. Good tip thank you.I don't know if there's a better way to do this, but when in reverse, I simply readjusted the driver's mirror up to be close to my normal position and it remembers. Now in reverse, only the passenger mirror moves - even after adjusting my normal mirror position in drive.
Took a couple tries, but the mirror doesn't appear to move at all now when reversing. Pro tip: by default, the mirror only moves down; if you're very careful about only pushing the up mirror adjustment, you have an easier time matching your normal driver position.
If you get it really wrong and can't get it to match, factory resetting the infotainment resets the reverse mirror behavior to factory.
all new owners should watch this at least once
Thank you it's working correctly now.Click the icon that looks like the Avengers logo to turn off the low speed camera assist
