Is it ok to change 15k maintenance?
When i did 10k complimentary today i was told that it will cost around 350$ and they even not changing oil. WTF.
Why should i need to pay for it? It is a Lexus GX and I'm expecting this car last for a good period of time. They mentioned something about cabin filter replacement. But i would rather do it myself with youtube.
I don't think it worth 350$ for this
- Rotate tires and adjust tire pressures as required
- Replace smart key battery*
- Clean air conditioner filter
- Reset maintenance reminder light
- Road-test vehicle
- Check installation of driver's floor mat*
- Inspect and adjust all fluid levels
- Inspect axle shaft boots
- Inspect ball joints and dust covers
- Inspect body
- Inspect brake lines and hoses
- Inspect engine coolant
- Inspect exhaust pipes and mounting
- Inspect rack and pinion steering assembly
- Inspect steering linkage and boots
- Visually inspect brake pads, calipers and rotor
