Tire thoughts for 25 OT
SFLGX
WNC
I thought I narrowed it down to wanting to get Pirelli Scorpion XTM AT's to replace my worn out OEM Toyo's. Only thing I'm struggling with is size.
The replacement Toyo AT III's in 265/70/R18 are SL load rated, have a tread width of 8.4in and weigh 43lbs and have 13.4/32nds of tread.
The Pirelli in 265/70/R18 only come in E load, have a tread width of 9.7in, weigh 54lbs, and have 14/32nds of tread.
There is also the Pirelli in 275/70/R18 which are SL load rated, have a tread with of 9.3in, weigh 47lbs, and have tread of 13/32nds.
From reviews the Pirelli's score very high (but that might be for the SL rated, not E rated). I don't need the E rating on a day to day basis, but I'm also looking to avoid kicking up too many rocks. I found this picture from someone on Facebook who went with the 275/70's and even though the tire width is only .3in wider (11in vs 10.7in for stock Toyo) the tread with being almost an inch wider is really noticeable.
Should I change my search to a different tire?
By your own numbers the 275/70R18 SL suits you better than the 265 E. Its tread is 9.3in vs 9.7in, so it should kick up fewer rocks. It's also 7lbs lighter per tire with the softer SL ride, though about half an inch taller than stock.
consider the Toyo AT3- EV, 275/70R18 in SL load. Weight is 45 pounds. I installed these last year on my 25 OT and recommended. More tread and less weight than Pirelli in same size. Much better handling than OEM. Mileage about the same, and they are known to wear well, believe a 65k warranty.
Those are discontinued:
