I found it was so annoying to turn off the automatic heated and ventilated seats from infotainment system. Maybe I didn't do it right. I like the automatic heated and ventilated in AUTO setting in general. But sometimes I need to turn off if it is too warm or cold. In order to turn off, I click on the icon (either heat or ventilate), it turn on manual heat or ventilate at max setting, then keep clicking for max, med, low, then it eventually it will turn off completely. It takes One, TWO, THREE, FOUR, FIVE click. This is dumb! Maybe I do something wrong and there is a quick way I don't know. How do you turn it off?
Second problem, I found on passenger side of automatic heated and ventilated seats setting AUTO. I expect "AUTO". When there is no one sitting on it, it should NOT turn on. However, I found if I set to AUTO, it still heats (I actually don't know) and ventilates (I can hear fan noise) until I turn it completely off. Com on, airbag knows if there is a person sit on it and turn if ON/OFF. Don't the same applies to heat and ventilation?
