LandBully Rear Hatch Light
  • Thread starter Thread starter RickBullotta
  • Start date Start date
Which version matches with the rest of the interior: cool white or warm white?
The warmer white (bright white) is described by LandBully as matching the OEM interior.
I went for the Warm White ( as described on both my invoice and shipping doc). It seems to match perfectly. I probably have it set at like 60% brightness setting.
Question for folks who have installed the land bully rear hatch light. Does it remember your light settings? For example, if you dim it to 30% or turn it off, does it stay at that setting through repeated opening and closing, turning car on and off, etc.? I am about to pull the trigger but concerned about times when I am not trying to brightly light up an area if I can leave it off or low without having to reach up and turn it off every time. Appreciate it if someone could confirm! thanks
I can confirm the light settings are saved and do not reset. If you dim at 30% it is saved at that setting. Once set at your desired illumination level it will remain that way until you change it. I just tried it!
Just saw this thread - I just posted pictures in my build thread. These lights (from wherever you get them) are worth the money and installation work.
In the photos below I have the single center-mount hatch light that Land Bully sells plus I have the two outer lights that are in the bottom of the tailgate hatch so the 2 lights aim almost straight rearward when the hatch is up.
View attachment 11069View attachment 11070
I am interested in seeing/hearing more about the two rear facing lights. Brand/install pics please 😃
this is what you are looking for REAR Hatch Camping lights (updated the link to an Amazon site instead of Aliexpress)
It replaces the existing switch housing on the right and the handle on the left
Awesome, thank you for confirming!!
