LandBully Rear Hatch Light
  • Thread starter Thread starter RickBullotta
  • Start date Start date
1) Install your new center light which ties to the power latch
2) For the double lights - connect the left light to the center light power and you're good to go - you do not need to run power back through the door and to the space by the jack as called out.
What a great little mod. 3 minute install, light is bright as hell and aimed directly at the cargo area. Not sure what the blank plate was for, but this should have been a stock accessory.
Just saw this thread - I just posted pictures in my build thread. These lights (from wherever you get them) are worth the money and installation work.
In the photos below I have the single center-mount hatch light that Land Bully sells plus I have the two outer lights that are in the bottom of the tailgate hatch so the 2 lights aim almost straight rearward when the hatch is up.
View attachment 11069View attachment 11070
Take my money….looks awesome!
Following up - the single LandBully light is way more than adequate on its own. I don't foresee putting any additional lighting back there.
Who bought what color from land bully? Warm or Hyper White?
Which one matches the OEM interior more?
This is definitely something that needed to be standard just like the mud guards!
And the freaking digital rear view mirror! - I am still trying to figure out how to make this work...
I bought the Hyper White. I didn't care to match existing lighting. The white is definitely a different hue, but it does the job well.
Did the same, hyper white. I am happy with it in the install video they show you can tap to adjust brightness but mine does not do that.
I have to push pretty hard for it to dim, but does it. It doesn't work if I tap it.
I ordered the warm and have been on backorder since the first week in May. They sent me an email the same day I ordered and said to expect delivery in late May or early June.
I think warm would be a better match, but I just wanted maximum light and went hyper. Happy that I did.
I don’t understand why Land Bully says this is the better match to the OEM lighting thats clearly not “warm”. Personally waiting to see some examples before purchasing.
Compared to the factory interior lighting the hyper white is clearly a "whiter" light. So I'd bet the warm white is the better match.
No affiliation, but another plug for this being a great bang for the buck mod. The factory couldn't have done it better. But doesn't matter because they chose to not even bother trying.
Love the light but like above, I can’t adjust my brightness …
