As the title states. Anybody running 285/70 tires on their stock 2024 OT/OT+? PFA
Planning to put 25+ OEM springs on my 2024 so ya wanna go 285/70 C-load. Would go 285/75 but want to avoid E-load tires. Still might bail on the springs and run 275s tho. I have time (OEMs are young). Re: wheels I’m looking to get some TEs down the roadHave you considered running one tire size down (275/70/18)? Seeing that you have a 24' OT, that size fills the wheel well nicely being that it sits 1" lower than the updated 1" factory lifts in the 25's and up. Not to mention that the 275s come in the SL load (and even EV version) for weight reduction as well (not sure if that matters to you).
Unless you were planning to lift it to go a few tire sizes up? Were you sticking with the factory wheels or aftermarket too?
@incognito.gx Are you going with Falkens? They are the only tires I could find in 285/70R18 that were C-load rated but they are 10 lbs heavier than the Nitto or Toyo in the same size (E-Load). Wondering if I missed another brand(?).Planning to put 25+ OEM springs on my 2024 so ya wanna go 285/70 C-load. Would go 285/75 but want to avoid E-load tires. Still might bail on the springs and run 275s tho. I have time (OEMs are young). Re: wheels I’m looking to get some TEs down the road
Got it - yeah I am also planning to slap on 285s (Toyo AT3) with TE37XTs when I get my 26' OT hopefully later in the year.Planning to put 25+ OEM springs on my 2024 so ya wanna go 285/70 C-load. Would go 285/75 but want to avoid E-load tires. Still might bail on the springs and run 275s tho. I have time (OEMs are young). Re: wheels I’m looking to get some TEs down the road
Oh sh*t good call. Ya super heavy@incognito.gx Are you going with Falkens? They are the only tires I could find in 285/70R18 that were C-load rated but they are 10 lbs heavier than the Nitto or Toyo in the same size (E-Load). Wondering if I missed another brand(?).
Nice - plan to mount them on the factory wheels or aftermarket?Just ordered at set of BFG KO3's 285/70r18. Will post later after the 25/'2026 OT 1" update lift is installed. Seems a great combo of drivability/looks and improved capabilitie.
Yup - definitely the safer route to take.Factory wheels, I like the look and should make fitment easier plus a full spare.
Not mounting prior to lift? Should fitJust ordered at set of BFG KO3's 285/70r18. Will post later after the 25/'2026 OT 1" update lift is installed. Seems a great combo of drivability/looks and improved capabilitie.
Thank you AE. I failed to thank @Matthew@LC250Mods for confirming the fit, he's a great vendor who knows his stuff.Looks great! Thanks for sharing photos and results from garage rub testing.
Let us know how the KO3’s go from a noise/ride perspective.Just ordered at set of BFG KO3's 285/70r18. Will post later after the 25/'2026 OT 1" update lift is installed. Seems a great combo of drivability/looks and improved capabilitie.
Thanks so much for the kind words. I'm happy I could be helpful!Thank you AE. I failed to thank @Matthew@LC250Mods for confirming the fit, he's a great vendor who knows his stuff.
