Tire rotation disaster (1 Viewer)
suberbielle1
Baton Rouge
Looking for some advice from the group on what I should be asking the dealership to inspect or replace after what happened to my 2024 GX 550 Luxury yesterday.
I brought my GX to the Lexus dealership for the 25,000-mile service, which included a tire rotation. I also had the oil changed.
After picking it up, I pulled onto the highway and once I got up to around 25–30 mph, the front end started shaking badly, the steering wheel was vibrating hard, and the GX was pulling hard to the left. I immediately turned around and headed back to the dealership.
As I turned off the highway into the dealership driveway, the left front of the GX suddenly dropped to the ground. I got out thinking I had blown a tire, but the entire driver’s-side front wheel had come off. There were NO lug nuts on the wheel studs. The GX was sitting on the driver’s-side front rotor/brake area, and the wheel was wedged underneath the wheel well.
My concern now is possible damage beyond just the wheel and lug nuts. The wheel was obviously loose and wobbling while I was driving, and then the full weight of that corner of the GX dropped onto the rotor/brake/suspension area when the wheel came off.
For those of you familiar with the GX 550, especially anyone with Lexus/Toyota technician or mechanical experience, what would you insist the dealership inspect or replace before accepting the vehicle back?
I’m thinking at minimum they need to thoroughly check the wheel and lug holes, studs, hub/wheel bearing, rotor, caliper, brake hose, ABS sensor, steering knuckle, tie rod, ball joints, control arms, CV axle and suspension components. I also plan to ask for a full four-wheel alignment with before-and-after measurements and a complete scan of the ABS/VSC/EPS systems.
I’m also concerned about the possibility of damage that may not be obvious during a visual inspection, particularly to the hub/bearing, steering or suspension components.
Would you insist on replacing the hub/bearing and rotor after an event like this even if they appear OK? Anything else specific to the GX 550 front suspension or drivetrain that I should have them check?
I want to make sure I cover everything before I accept the GX back from the dealership.
Appreciate any advice from the group
WOW - you are lucky things did not go even worse and into a horrific accident. Where is the vehicle and do you have pictures of the 'no lug nuts.' I would skip the service advisor and walk right to the Service Manager or GM in addition I would place a call to Lexus North America - I imagine they will have your back.
Wow I’m really sorry that happened to you. I’m not really knowledgeable but just wanted to ask you what the dealership’s reaction was? Also it would be great if you could name and shame them but I totally understand if you don’t think its’s a good idea right now.
I'm not a Lexus or Toyota technician.
With that said, I'd treat this like any other maintenance repair, proceed as if the burden is not on you to tell the dealership what to inspect, repair or replace. They'll know what to do, that's their job ... granted they seem to have failed at it on the service work that caused this.
Since they caused the problem, and since the wheel fell off in their driveway, I'd think they will be extra-super eager to fix things and to get you back on the road. Still, do ask pointed questions on what they plan to do, say "I need to know for my own peace of mind...and for how it will show in any CarFax history report and vehicle service history." Because you want to protect your investment.
In addition to this, you have the escalations with the dealership, in both the service dept., and the dealership management. I would not hesitate to use either or both of these avenues right away. In particular with the dealership mgmt, where I'd be proactive to request an in person meeting to clarify 1) you need confidence in the work, and 2) you want to know how or if the repair work will affect the value of your vehicle months and years from now.
Put what they say in these discussions in writing, so you have a record. And make it obvious you are taking notes, as "ah, ... just a minute while I write this down...".
I'll also be interested to know what dealership.
It sounds like you are in Baton Rouge, Louisiana, from your member data.
There is likely NOT another close by Lexus dealer near to you - so your displeasure MUST be made known to the highest level of that dealership and to corporate customer service.
This is a big deal from both a safety and customer service standpoint.
Lexus takes their customer service very very seriously. I would definitely recommend reaching out to corporate, and at minimum the service manager / GM at your dealership.
From your description damage may have occurred to all of the components mentioned. Requesting both reimbursement for loss in value and independent vehicle assessment by a “corporate” service specialist. This will show up and Carfax and your vehicle WILL (unfortunately) loose value.
I would recommend requesting a $3500 credit towards a 10 year /100k warranty for your “peace of mind.”
Lastly, this type of “sentinel event” should result in a systems change at that dealership, such that this never happens to another Lexus customer.
When I have services done, I speak directly to the mechanic - ask how the rotation was done. When particular torque specs are an expectation - I will ask specifics.
One last thought, it’s not unreasonable to ask to have them buy back your vehicle and put you on the list for a replacement.
Good luck navigating this tribulation - sorry this happened to you. Someone really wasn’t paying attention. Hopefully this results in a new systems update to assure it doesn’t occur again.
Emed
Wow man so sorry this happened. Hope you get it sorted to your satisfaction. This is why I always torque the lugs myself before leaving the dealership. In fact, at my 15k service I forgot to bring my wrench and when I got home (45mi away) only 3 of my 20 lugs were torqued properly😳. Thank GOD i checked, as some of them I was able to hand tighten. I was NOT happy. Still need to file a complaint
What do you torque yours to?
It's horrible to hear how a dealer botched something so basic -- and could've easily injured you as a result. My only experience with this level of dealership stupidity was 30+ years ago. Picked up my Saab 9000 from service and was driving across the Golden Gate Bridge, when the steering wheel came off completely! I was lucky to be able to quickly push it back in place -- but that could've ended very badly. That bridge is so tight with no center divider, so there's ZERO margin for error...
To me this should result in the Lexus dealership in Baton Rouge breaking out a black marker, drawing an Ishikawa diagram and doing some root cause analysis.
Man! If dealers are so irresponsible that customers need to pick up their cars with a torque wrench in hand that’s dreadful!!!
OP - please do an update with final outcome on your story - we are all interested.
Happened to me years ago with my Touareg. Luckily the wheel rode the brake disc and did't go flying at 40 MPH. I was in DTLA and people were everywhere. The lug nuts literally shot across the street and could have hurt someone just by themselves.
I raised hell at the dealer. In the end not much else you can do, there are no penalties for "almost" hurting someone :( But yeah, let them know how disappointed you are, get under there yourself with a flashlight and camera, and expect them to make it perfect. In the end my Treg had essentially no damage, hopefully the same with you.
I usually check the torque on the nuts after wheels off service when I get the car back. And then every few months before big trips. It sucks, but you really can't seem to trust anyone in this world...
Scary how poor the service seems to be at so many dealerships now. Importantly, I'm glad you're okay. What you suggested should cover it. I'd primarily be worried about the lower control arm, brake rotor, dust shield, and brake lines.
Sorry for that bad experience. I would indeed escalate this to the dealership management and get some kind of warranty letter if something goes wrong down the road (especially if anything goes into Carfax eventually).
Not exactly the same experience but when I had a RX I got a flat and went to the closest Lexus dealership. They replaced the tire but once home I noticed a bunch of dings on the rim, like they had used a hammer to install the tire. They also had scratched the car body above the tire. I sent them pictures and they agreed to replace the rim and fixed the body ($500 on them). Their excuse was they had given the job to a newbie so no QA whatsoever...I never went back to this dealership...
Absolutely, I’d be leading the RCCA myself!
These dealers are clowns anymore, fortunately Lexus seems to be somewhat competent. Dealing with Mazda for my spouse’s vehicle on the other hand… what a shit show!
