24 vs 25 OT OEM 1” Lift Details via reddit (1 Viewer)
This is probably a long shot but I'm gonna ask it anyways... but any of you 2025 & up owners (with the updated 1" spring lift) swap out the rear springs to the shorter 2024 set, in efforts to reduce the crazy amount of rake that's in the rear?
I have a 2024 and have changed to the 2025 springs in front and rear for the extra inch. The rake is designed so the vehicle is flat when you have weight in the back or haul a trailer. I'm not sure I'd see any advantage to changing the rears to shorter ones as you would suddenly have a tall nose
I don't plan to haul anything heavy with my GX so I'm not worried on that regard (I have a truck for that). And in theory, I'd imagine there'd still be a rake with the 24' rear springs, just not as pronounced.
I’m just Leary of changing the geometry of the vehicle. Even 500# or so in the back will change the level of the rear. But at the end of the day - it’s your rig and you have to like the look.
Agree, you can reduce the height but would lose the heavy carry without it squatting down. It would still work, and if just performing limited heavy hauls should do the trick and keep the stance more level for day to day use. Changing out the rear springs may be less impact on the front setup as well. The shocks would be ok as well.
Can't you just lift the front instead to achieve a more leveled look?
I prefer not to add a level kit to the front. Want to keep stock suspension as much as possible.
i went from 2024 springs to 2025 front springs and love the ride. Lexus of San ta Barbara did the swap.
Looking to do the same thing due to tight garage clearance. Curious if you are planning to do a recalibration on sensors and re-aiming of the headlights or leave them as is? A local shop said "most of their customers opt not to" but I'm concerned about sensors and suspension not behaving correctly.
I'm hoping no codes or sensors go off since technically it's just the rear springs that would be swapped. Also hoping the rake is tolerable so I don't have to consider this mod. I wouldn't think the GX driving characteristics would drastically change much, but I'm no professional in this trade so hard to say until it's done.
