24 vs 25 OT OEM 1” Lift Details via reddit (1 Viewer)
can you be specific on what exactly they broke.... just so you know ... the truck will drive without the AVS plugged in and you will not have a light
They called and said “the wire on the strut was either broke when it came in or we broke it during install…” 99.9% sure it was broken at install.
I’ve got an hour ride one way back from the shop. They won’t get a new one in for a few days
They might have to provide a new Shock depending on what end broke
I’ll add it to the list for my next visit. Had a local shop put the Wescott
Kit up and they “broke” the AVS wire during install. Trying to determine if I can drive it while we wait on the replacement or if it should stay at the shop.
Have they accepted responsibility to fix?
24 OT+ with 2025 front coil springs to level it out
anyone with a 24 OT/+ have a dealer invoice for the front job? I inquired with my dealer and I got the usual "never heard of it". Which is what I got about every single KB I presented to them. I plan on going somewhere else, but probably helpful to have an example of work done. I only need the work/parts line items. TIA.
LOOKING FOR THE SAME SET UP FOR MY 2024 OT+. CONFIRMING YOU ONLY INSTALLED 2025 FRONT COIL SPRINGS, NOT REAR? ALSO, WHAT SIZE TIRES ARE YOU USING ON THE OEM OT WHEELS? LOOKING TO INSTALL 285/70R18.
Yes 285/70 on stockers and it still fits in the spare well
Installing just the front to level out against the rear is short sighted in my opinion as I do haul close to the weight load many times per month. If you did just the fonts to level, with a heavy load now you have the nose above the rear with is just silly. Add a trailer and you are in a world of hurt,
I dont tow, at least not yet…. I still have a slight tilt, but Im very glad I only did the front. Im running stock tires and wheels, until they need replacing, then Im going to 285/75/R18 with a 40 offset.
For anybody that’s swapped the 2025+ springs into their 2024, do you also need the 2025+ struts or is it a straight swap?
Thats what I thought. Shop didn’t seen to think it would be the same strut but I told them im 99.9% sure it is. Thanks man
I can confirm same struts. I had it done at the dealership and only parts they charged me for were the springs.
FYI, I have my 2 original 2024 Overtrail front shocks/struts with good AVS wires. I've sold the top hats to another forum member that needed them and I don't have the spring perches either. I also have the stock 2024 front springs but those are probably not of any use to anyone. I'll sell 1 or 2 front shocks for the price of shipping and shipping supplies (bubble wrap & box).
