Clean and Hidden: 30" Lighting for the Lexus GX550 (1 Viewer)
MandRautomotive
📦 Supporting Vendor
Burbank, CA
If you’re running a 2024+ Lexus GX550 and want more forward lighting without changing the clean look of the front end, our 30" Light Bar mounts behind the lower grille for a low-profile, vehicle-specific setup.
The kit is a bolt-on design using factory mounting points, with no cutting or drilling required, and it’s designed not to interfere with the active grille shutters. White, amber, and white-with-amber-DRL options are available.
Here’s the light output video so you can see what the 30" setup looks like after dark:
It’s a good option for anyone who wants a substantial lighting upgrade while keeping everything tucked behind the grille.
For off-road use only.
If anyone has questions about fitment or installation, feel free to ask.
Quick update for anyone checking out the 2024+ Lexus GX550 30" Light Bar — here’s another video showing the setup in action:
It gives you a good look at the clean, behind-the-grille placement and how the 30" setup fits into the front end without taking away from the factory look.
If anyone has questions about the setup, fitment, or installation, feel free to ask.
You folks make outstanding light bars - absolutely love mine!!
@YellowLab Thanks, really glad you're loving yours!
For anyone else looking, here's another shot of the 30" bar on the GX550, tucked behind the lower grille.
  • Fits 2024–2026 Lexus GX550
  • Installs behind the lower grille
  • Doesn't interfere with radiator airflow
  • Doesn't interfere with active grille shutters
  • Metal bracket is powder coated black
  • No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware
  • Every SLIM bar uses a Spot & Flood pattern, blending a focused spot beam with wide flood coverage for a balance between distance and width
2024+ Lexus GX550 30in Light Bar
