Hey everyone,
For anyone looking to add more usable lighting to the 2024+ Lexus GX550 without taking away from the clean factory look, we wanted to share our M&R Automotive Dual 12" Light Bar Kit for the Lexus GX550.This setup uses two compact light bars, one on each side of the lower grille, keeping the lights tucked behind the factory bodywork. Together, the white version produces up to 7,400 lumens, giving you a substantial boost in forward lighting for trails, back roads, camping, and other situations where you need more visibility.
A few highlights:
- Two 12" light bars
- Fits 2024–2026 Lexus GX550
- One bar mounts on each side of the lower grille
- Up to 7,400 lumens with the white setup
- Spot + flood beam pattern
- White, amber, or white with amber DRL backglow
- Vehicle-specific powder-coated metal brackets
- No cutting or drilling required
- Uses factory openings and hardware
- Does not interfere with the active grille shutters
- Does not affect radiator cooling
- Lifetime warranty
- Off-road use only
We like this setup for the GX because when the lights are off, they're easy to miss. Turn them on, and you've got considerably more usable lighting without having a large exposed bar across the bumper or roof.
For the GX550 owners here, which setup would you choose — dual white, dual amber, or white with the amber DRL backglow?
