Rago Ditch Light Brackets - Baja Designs Squadron Pro 2.0 (1 Viewer)
Abarbs30
🏆 GX of the Month
COLORADO
Did the install of the Rago ditch light brackets. I'm not handy and it took me about 2 hours with some trial an error. You need a rivet tool, they tell you a 25/64 drill bit but you can do with a 3/8" which you'll have anyway. Once finished I think the look is very clean and I like it better than the CBI or Westcott that block the gap between the mirror and the A-pillar, find myself looking through that often when off road to see the edge of my front tires. Already had a Garmin Switch installed so wiring into that was easy. Definitely happy with the results.
