Tachometer in Heads-Up Display
Bluegill
2x 🏆 GX of the Month
Scottsdale, AZ
This is a neat little trick....
Under the little gear setting icon menu, go to "Head up display" and make sure "Display customization" is on "Full". See the first photo.
On the steering wheel, click the "Lane departure assist" button to turn it OFF so the icon is off on the digital dash display. See the second photo.
Then on the steering wheel click the Cruise control MODE button to switch the cruise control from Adaptive to regular Cruise Control Mode. See the third and fourth photos. The digital dash display will then display a message about turning adaptive cruise control back on and you can hit the return key on the steering wheel or just wait about 10 seconds and the message will go away.
Then you'll have the tachometer on the heads-up display.
NOTE - the tach won't display in ECO mode.
The next time you start the truck, you have to switch back to regular cruise control instead of adaptive again and it will display the tach.
How did you manage to display both the tachometer and speedometer at the same time? I tried switching between displays 1, 2, and 3, but it didn’t work.
I believe that is under the “meter” setting. I will have to double check.
Ty good work
Yes the tack is great. Love the red white and blue graphic sweep. Posted a pic on a track with it on.
Great picture walk through of the button presses. It has illudid me for a couple weeks as it was not straight forward in the user manual. Definitely nice to have if pushing it and manually shifting. After the HUD tack and driving info, the normal cluster doesn't get the attention I used to give it.
I checked and it is Meter Type 2.
Go to the little gear Settings icon menu, then Vehicle Customize, then Meter, then select Type 2.
I have been wishing there was a way to get the HUD to show that tach. Followed these steps (thank you by the way) but unfortunately it’s not working for me. HUD on Full, cruise control switched to regular cruise, and lane keep assist setting to off. No tach.
I wonder if there is some other setting I am missing. I was not in eco mode but running in sport mode. Tough to photograph, so I took one with HUD in focus and one with dash in focus.
Switching two meter 2 is a nice alternate setup for the dash though.
You can see the two angled lines in your HUD - this indicates that some kind of lane keeping assist is still activated as AtomicEric noted.
So I got this to work but ... it doesn't stay the next time I start the car. The lane departure and proactive driving assist remains off but the cruise control is defaulting back to adaptive mode. I have to press mode to go back to standard cruise control and it tach will appear. After that it show a message in the HUD about pressing another button to activating systems.
I enjoyed actually driving the truck myself and not have it brake itself and push me back into lanes. It would be annoying to cycle through cruise modes each time I start up. I tried using regular cruise for a bit to see if it remembers that as my last mode activated.
oh this is cool...I'm still trying to figure out how to set my gauges. I really need to spend some time going through all the settings. The tach is really cool
