I've been meaning to get a third key fob. But I haven't pulled the trigger yet. Mostly because it's not my highest priority and also because I'm not completely 100% clear -- I'm at 95% -- you can do it yourself.
There are some YT videos out there that describe a procedure of a.) Put the vehicle in accessory mode, b.) touch a working key fob to the start button, c.) hold the new key against the start button until you hear some number of beeps, d.) wait a few seconds, up to 60 seconds, for everything to register, and e.) test-check the functions to confirm everything is working as expected.
I've also read f.) you must or should do the above where the vehicle can communicate in the normal, usual ways with Lexus-Toyota servers, e.g., not in an underground garage or an all metal building, and g.) if a new key is successfully registered then a message will be displayed for 60 seconds on the multi-information display that cannot be cleared for 10 days.
Here's what I know 100%:
There are different names used in the Owner's Manual, in parts catalogs and in service manuals.
Here's the Owner's Manual using the words "Electronic Keys":
Parts.lexus.com uses the words "Smart Key," with full name Smart Key Supply Transmitter Sub-Assembly.
Maintenance manuals are a mixed bag, they use "digital key", "owner key" and "Smart Access System with Push-button Start," but not (not much) "Smart Key Supply Transmitter Sub-Assembly." It's really hard to follow, for me. Edit to add, they also use the words "IMMOBILISER KEY ID."
The part number is 8990H-0E622.
It's $223 from Lexus:
Genuine Lexus Smart Key Supply Transmitter Sub-Assembly for keyless entry, secure vehicle communication, and exact fit.
parts.lexus.com
$163 from LexusPartsNow:
Genuine 8990H-0E622 Electrical Key Transmitter Sub-Assembly fits 2023-2025 Lexus models. LexusPartsNow offers 8990H0E622 for $163.47.
www.lexuspartsnow.com
From RockAuto, the Big Lots of parts, this Key Fob has never been listed. I've been watching for a few months and I decided RockAuto will probably never sell because Lexus keeps a tight control of the supply chain for items like this.
As is always the case with LexusPartsNow their prices go up and down regularly, depending on dealers excess inventory levels. They are legit for Lexus OEM parts and I wouldn't hesitate to buy key fobs from them. For key fobs you can expect a call from the actual dealer that gets the order to ask for proof or verification of the VIN number, i.e., you send them pictures. This is based on my experience with their Ford branded (FordPartsGiant) website buying spare key fobs years ago.
As I said I'm at the 95% confidence level this will work. I'm comfortable trying this, and it's on my to do list, just haven't gotten to it yet. My take is the worst that can happen is you purchase a new key yourself, you cannot get it to work and you have to take to a dealer and pay them to do it, less the cost of a new key fob, and maybe an up-charge for not buying the part through them. Worst case scenario tip: Somehow if you attempt the new key registration, and it doesn't work after 10 attempts, and then for whatever reason you disconnect the battery you may have to use the mechanical keys until you can get to a dealer.
P.S: I now see the the original post from
@jordanfsl is from six month ago, so I'll be interested to find out if it worked out.
