Starting a new Thread on the subject of adding a StarLink Mini to my GX but without the need for power cables and using a roof rack mount that will allow the quick removal of the StarLink. For the past few weeks, I've been reviewing the comments on the GXForum as well as reviewing various on line reviews about how people addressed this issue. Here's the set-up I am pursuing (still waiting for a few critical parts to show up):
1) Starting with the StarLink Mini - Unit received and activated.
2) PeakDo L2 Battery unit which attaches directly to the StarLink Mini - Unit received and activated. So far, works fine. I did find an app that allows remote monitoring without the need to login to the PeakDo website (LinkPower) - it does require an annual subscription of $19.95 but my initial thoughts are it's worth it to see the status of the battery unit remotely via Bluetooth - so you do need to be relatively close to the StarLink. If you want Wifi access, I guess this is where the L3 unit may be useful but, for me, I didn't see the value.
3) And this one, if it works, will allow me to mount this on my Sherpa Atlas roof rack. - I product from Smart Touring Systems (STS) out of Australia called the QuickFit Mini Mount - basically an enclosed container that you attach to the roof rack that has a lockable hatch to remove the Starlink. It is large enough to accomodate the PeakDo attachment as well which means no external power cables required! - The catch is of course, you are limited to roughly 4 hours of run time (until the battery drains) unless you do run a cable to charge the PeakDo or, theoretically, mount a solar panel on the roof as well. The other catch is that this mount is not cheap... around $400 for the unit. I ordered the unit on Sept 6 and was just informed it made it to the US today... It has not yet cleared customs so not sure when it will arrive.
Testing to date:
I set up the Starlink outside my home. Getting good reception - See photo below: 222MBPS Downstream, 17 MBPS Upstream. The StarLink is drawing about 22W, and the PeakDo is predicting 4Hours of battery life. I attached a small clip of the quality of video streaming - at least in a stationary position.
The real test will be once the STS Mount shows up and I can install and operate from the GX. Concerns are, does it work as advertised and, also, any thermal issues given the enclosure. We shall see...
Stay tuned!
Testing to date:
Stay tuned!
