GX 550 V35 engine Recall Potential (6 Viewers)
Spearone
Largo, Florida
So, I am strongly considering buying a new 2026 GX 550 Overtrail. However this V35 engine recall has me a bit on edge as I keep my vehicles 10 to 14 years on average. I see the 2024 GX has been included in the recall along with many 2022-2025 Tundras. Toyota initially said the engine recall only affected the engines made in Alabama and engines made in Tahara were unaffected. If this is true, why are some of the 2024 GX 550’s now included in the recall. Are 2025 and 2026 GX 550’s soon going to be included in that recall?
I recently saw a YouTube video where a guy got a 2023 Tundra engine (38k miles) with a catastrophic failure and completely disassembled it. His analysis showed that metal filings were likely not the source of the failures because there were not metal filings distributed throughout the common oiled areas of the engine. Instead, there was significant wear/burning on the main crankshaft bearings which in his opinion was likely caused by insufficient lubrication. These engines use 20W oil vs. which is a much lighter weight oil than many engines use. This guy claims that this lighter weight oil in combination with high stress levels being put on a relatively small engine by a large truck/towing, combined with oil changes being stretched out too far, create a “perfect storm” resulting in catastrophic engine failure. If there is an inherent engine design problem, then this problem extends to all the V35 engines regardless of where they were produced.
A GX 550 is a lighter weight vehicle than a tundra but its still a relatively heavy vehicle. If most of these GX 550’s are “pavement pushers”, and most are not towing heavy boats or trailers, maybe this is why there have been far fewer failures in the GX 550’s vs the Tundra as they are not asked to power as heavy of a load. However, that still doesn’t mean your GX 550 engine is safe from a catastrophic failure once it reaches 50, 80, or 100k miles. This would be a nightmare scenario for me as I only drive about 8,000 miles per year. Unfortunately my warranty will run out based on time not mileage if or when an engine failure occurs. I am I wrong in my thinking on this?
I don’t have answers to all your questions, but in essence the gist seems to be that most are calling BS on Toyota’s manufacturing debris claim and believe there is more of a design issue going on. Now the bearing failures seem to have been addressed since there was a more “robust” main bearing put on engines built after April 2024.
Is that the fix to these problems? That’s TBD. If it is then it’s likely that neither 2025 nor 2026 gx’s will be included in the recall. If it’s not the fix, then Toyota is gonna have some splainin to do because they’re seemingly replacing these bad engines with an engine that doesn’t fix the issue.
I don’t think there have been many, if any, gx’s that have had a failed main bearing. It might be because this is the detuned version of the v35 and isn’t putting as much stress and strain in the main bearing.
I’ve had my gx since April 2025. No real issues other than the transmission downshift issue that was addressed with a tsb. It’s an expensive vehicle and I certainly don’t love the idea that the engine could be bad, but you are protected by a 6 year warranty
I had not heard that a beefier main bearing had been installed in the 2025 & 2026 model year engines. Thanks for that info. Another video I watched recommended changing the oil in these engines every 3,000 to 3,500 miles to add some additional protection.
There's a lot of (miss)information on that topic online. Who knows what's truth, what's clickbait, and what's AI generated hallucination? Only Toyota knows what's going on. My personal take is to follow the money. Assuming Toyota, as any other business, is in the business of making money, it seems very unlikely to me that they would be replacing 250k engines for the heck of it. If the problem was wrong oil specs wouldn't the smarter business decision be to change oil recommendation? Also 1UR-FE and 3UR-FE also called for 0W-20 so 🤷‍♂️
I am planning on keeping my 06/2025 GX for a long time. I am towing a trailer during spring / summer months. If the engine grandes so be it. I'll wory about it then :)
    Votes: 7 77.8%
    Votes: 1 11.1%
    Votes: 1 11.1%
