Keep about 12 feet of clear fuel-rated tubing stashed in the truck or in a bail-out-bag. The tubing, along with a few simple tools, can get you all the fuel you need for quite a while if the shit hits the fan.
Sonny half of an our usable tank (9.05 gallons) is only about 135 miles of distance. Very different for example than my sons Subaru which will take him 250 miles.Good point. To add to it, what if you need to get somewhere suddenly thats further than 3/4 tank? Better to refill every time you drive the car just to be safe![]()
That 2.1G is in the reserve well. Thats the indention/well in the fuel tank where the fuel pump/sender assembly resides. One could run a GX down to no gas, but there are 2 things to be concerned with in doing that:There's another factor in the DTE calculation algorithm that I observed again today for the umpteenth time.
As you approach empty, starting approximately at the 60 MTE point, the more generous (in your favor) the calculated MTE value becomes.
Today's example I was 130 miles away from a favorite Costco gas station. The MTE showed 95 MTE, so a deficit of 35 miles. The deficit lessened the closer I got to empty and to the gas station. At 60 miles away the DTE was 20, (so it went from 35 to 20). When the MTE finally reached zero I was still 12 miles away. This was all interstate highway driving, except the last 2 miles.
Still I only got 19.06 gallons into the tank even with topping off (pressing the detent a few more times after it clicks off). 21.14 Gallons - 19.06 gallons = 2.08 Gal, so 2.1 gallons still hiding in there somewhere
Based on every car I've owned, this is quite different. A lot of the above smacks of poor design, or cost-saving choices. Running a diesel close to empty I understand -- a lot can go wrong if you run it dry. Running a vehicle with Overland in the name close to empty should NOT be a problem, IMHO. As always, YMMV...That 2.1G is in the reserve well. Thats the indention/well in the fuel tank where the fuel pump/sender assembly resides. One could run a GX down to no gas, but there are 2 things to be concerned with in doing that:
- Fuel pump longevity. The fuel pump lives in that well so its insured to always have fuel surrounding it helping keep it cool. You really don’t want to run the fuel pump dry. Its constantly running in a circulation loop.
- No fuel filter. Our GX (& many Toyotas models) do not have a replaceable fuel filter. They have a fuel screen on the intake of the fuel pump that is fixed & permanent. Taking the fuel level to the bare minimum you take a chance of ingesting what debris might have settled somewhere in the tank.
Just keep enough fuel to keep the fuel pump happy - at least 2.1G from your research.
Great info, thanks for posting. I think use scenarios dictate one's response to this. Range has always been critical to me, as I like to drive back roads instead of freeways, where possible. Until recently I was driving Denver to Austin, 4-6 times a year, with no freeways except the Lubbock to Amarillo stretch. I had an Escalade Duramax with a 640-mile range, as my previous Navigator made me feel like I was living dangerously given that West TX and Eastern CO both contain a whole lot of nothing. So, though I understand the engineering, it's hard for me to not consider this a suboptimal solution. If fuel pump reliability can be an issue if you use 90% of the fuel, maybe a redesign (or a significantly larger fuel tank) should be considered? Now, please excuse me while I go yell at the clouds...The “empty / refuel now” message from your GX may not be completely about “reserve miles”:
I think GR8Santini is quite right!
Modern fuel tanks utilize fuel to cool the fuel pump. When there is no fuel around the pump (overtime) they tend to overheat and fail (as with my 550 bmw, which has had more than one fuel pump fail in the course of its 12 year lifetime.) - despite (in the case of that vehicle) consistently getting fueled at 1/4 tank. (This was modified to 1/2 tank refuels in recent years).
In theory, running very low on fuel reduces the heat dissipation from the pump and overtime may contribute to pump failure.
I can’t say at what capacity the fuel pump becomes at risk for being damaged in the GX 550, but i wager to guess the quantity is somewhere around the 2-3 gallon mark, and possibly why the fueling system and its “empty” cut offs were determined by Toyota engineers.
The “empty” fuel mark may have been chosen both as for reserve miles for the driver and to protect the longevity of the fuel pump.
- a good theoretical question if someone has a connection with Lexus engineering.
