I realized a while ago that my winch wasn't working. Been meaning to correct this as there is no reason to drag around an expensive and heavy winch up front if it doesn't freakin' work.
I traced all the electric lines and it was connected fine and the winch was receiving power. I reached out to Overland Vehicle Systems (OVS) where I purchased this 12k SCAR winch and they sent me a troubleshooting guide. Fun fact: SCAR stands for Submersible Compact Amphibious Recovery. I was very slightly less than enamored with the idea of going through the tedious and maddening task of tearing off the front end and likely removing the front bumper again. I pushed them to just send me a replacement winch so I could dedicate a day to swapping it out and I'd send them back the original. They said "um we don't think so" and then one of the reps told me it is probably the little on/off switch on the winch - I pushed back and he said "trust me, it's the switch." Seems to be a common problem. They sent me 2 new switches and I finally got around to changing it out.
I was adamantly against tearing off the front of the truck so I tried to go down through the top end (removed that giant flat black plastic cover immediately behind the grill) and no dice. I was able to remove the switch with one arm down from the top behind the grill and the other hand holding the wires through the front of the grill with a long needle nose pliers. I thought awesome this will be easy but one of the wires was severed and it came apart as I disconnected it from one of the terminals/tabs on the switch. I was very impressed that this 12,000-lb-rated heavy duty waterproof winch is apparently frequently incapacitated by switch wires where the engineers chose a gauge roughly equal to newborn baby hair.
So, of courses I tore off the front of the truck and fixed it. Works like a champ now. It better keep working like a champ or this thing will get an overall D for dogshit rating from me.
I also found that most of my electrical connections were still waterproof but the plastic connecters have suffered. Plastic is already brittle and cracking apart. I couldn't disconnect a harness on the driver's side because it was jammed with sand. I tore apart the outer plastic shell trying to get it apart with vice grips.
My passenger side fog light has been flickering and the passenger side turn light next to the fog left the chat months ago. I checked it all and found that the Hyuga turn bulb (actually same as thier fog bulb) was probably just burnt out. I was also missing a 10mm bolt from a plastic housing piece that covers the fog and turn bulbs and connects it to the main front piece. Must have rattled out. The Hyuga bulbs were therefore loose and constantly shaking and vibrating in their housings. The area behind the main front plastic face-lift mask on these trucks is an absolutely non-sensical maze of plastic pieces on top of plastic pieces held together by hope, love, depression, and various screws, 10mm bolts, and the the discarded G-strings of over-50 strippers.
Got a replacment pair of Hyuga bulbs on the way. Went with Amber this time because it reminds me of a stripper I once knew.
Top tab is unused and absent from the newer replacement switches.
Switch removed - the top frayed wire and middle wire are connected together with a jumper tab and they connect to the bottom tab on the switch. Top wire broke off from the tab on middle wire.
I wired the two wires together with one of those solder-in-middle butt connector that you heat up and it makes a good soldered connection. I followed up with a long shrink-wrap over the whole thing (not pictured)
New baby-hair-wire switch installed. Better keep working.
