Thanks, I actually bought a gas can yesterday because I was worried about the MPG while towing!Sweet ride. Plan on stopping for gas often. Really often. Make sure you get your trailer brake controller setup BEFORE you leave.
Thanks! Mine is a ‘76 base 2k2. Is that your E90 M3 as well? I think I recognize your username from M3Post. I own an E92 M3 myself.Beautiful 2002! We are not planning on making the Vintage this year but we might drive up for the day. Here is our '74 Tii.
Yes, that was my M3... still regret selling it!Thanks! Mine is a ‘76 base 2k2. Is that your E90 M3 as well? I think I recognize your username from M3Post. I own an E92 M3 myself.View attachment 10718
I was considering selling mine too but it's a 2013 6MT with less than 30,000 miles so I decided to keep it and see where the values end up going. Hope you can make it to the Vintage, let me know if you decide to go!Yes, that was my M3... still regret selling it!
Ok.The rear springs are from Dobinson. They provide a 1 inch lift with a higher load rating. I'm on the road right now and forget the number. The lift really made the difference on the leveling of the ride with the camper hooked up. Otherwise, the GX looks like it got kicked in the fanny a little bit. I know that look annoys some but it doesn't bother me and my satisfaction comes from knowing how well it works towing the camper. And we will be doing that a lot.
I don't know the answer to your question about the bump stops as I had an offroad shop install them for me. I'm an older dude and with my knees and all I have reputable shops do all this work for me.
It's a 2019 Livin Lite Quicksilver 20x7 with an all aluminum frame. Weighs 3,850 dry. Think they got bought and only make the travel trailer versions now, if at all. Towing just may be the biggest reason we got a GX instead of a LC.Nice setup! What trailer is that?
Good tow lines. Are you using airbags?
Not yet, there trailer is all aluminum and is basically empty in the picture. I typically will carry 1 or 2 1000 lb Harleys and some tools and gear to add her up to no more than a worst case of 5000lbs. I would like to install a weight distribution system but can’t because of the aluminum frame. I installed inside the coil helper air bags in my 4 Runner and that worked great, but haven’t found them for the GX yet.Good tow lines. Are you using airbags?
