Largest Tire on GX 550
This is s pic with the phone flush to the door. iPhone
It does work:
Here are several all-terrain tires in the size 275/50R22, each from different reputable brands:
1. Nitto Ridge Grappler
  • Type: Hybrid (Mud-Terrain + All-Terrain)
  • Pros: Aggressive look, quiet for an A/T, excellent off-road traction
  • Cons: Slightly heavier, premium price
2. Toyo Open Country A/T III
  • Type: All-Terrain
  • Pros: Excellent wet/dry grip, 65,000-mile treadwear warranty
  • Cons: Less aggressive than hybrid-style tires
3. Falken Wildpeak A/T3W
  • Type: All-Terrain
  • Pros: Good snow performance (3PMSF rated), durable sidewall
  • Cons: Slightly noisy at highway speeds
4. BFGoodrich All-Terrain T/A KO2
  • Type: Legendary All-Terrain
  • Pros: Rugged, great off-road durability, 3PMSF rated
  • Cons: Can ride stiff on lighter vehicles
5. Goodyear Wrangler TrailRunner A/T
  • Type: All-Terrain
  • Pros: Budget-friendly, balanced road/off-road performance
  • Cons: Less aggressive sidewall and tread
6. Cooper Discoverer AT3 XLT
  • Type: All-Terrain
  • Pros: Tough tread compound, great for towing and hauling
  • Cons: May not be as aggressive in loose mud/sand
Let me know if you’re looking for:
  • quietest all-terrain tire
  • best for snow
  • longest tread life
  • or budget-friendly options
It does work:
  • Type: All-Terrain
  • Type: All-Terrain
  • Type: All-Terrain
  • Type: All-Terrain
  • best for snow
Thanks man
It does work:
  • Type: All-Terrain
  • Type: All-Terrain
  • Type: All-Terrain
  • Type: All-Terrain
  • best for snow
By any chance will these fit my oem rims from my luxury plus trim? Thank you for the list!!
Hello, I am buying the Westcott 2.5 inch lift. What is the largest tire I can fit on this without doing any trimming, I also want a little poke on the sides. Thanks again
Ask Westcott, they are pros and will steer you in the right direction. I was there last week, talked about this and they showed me numerous pics of GX wheel/lift combos they have done. Got me thinking about it!
I run the westcott kit with a 17x8.5 et35 and a 35x12.5 tyre, had to do very minor trimming on the inside lower edge of the bumper, 10mm or so. Otherwise you could go the next size down, like a 305/70 r17 (if running 17's).
