OK so what exactly do I need to do and parts needed for the best smoothest ride quality for the front and rear suspension without raising it or doing anything to make it not feel smooth?
Pleasure speaking with you today Jerry and if you have any questions feel free to reach back out either here or via phone.Mathew, Somehow my post is getting mixed in with my wife's post on the GX suspension. She started the conversation and I figured I should jump in and handle it. So referring to my last reply, the parts needed for front and back would be appreciated.
For me, shocks, springs and UCAs are the plan, with goal of improving highway ride quality and offroad ability. I took a shortcut on one of my prior diesel trucks (just turned keys, no UCAs) and did the same with Eibach lift springs for a Hyundai Santa Cruz. in both cases, down travel suffered and overall performance suffered for the sake of height. Fingers crossed that I'm doing it right this time around.What direction are most of you leaning so far on the GX?
You're on the right track. Let me know if you need any recommendations on specific springs or dampers and we'd love to get you dialed in.For me, shocks, springs and UCAs are the plan, with goal of improving highway ride quality and offroad ability. I took a shortcut on one of my prior diesel trucks (just turned keys, no UCAs) and did the same with Eibach lift springs for a Hyundai Santa Cruz. in both cases, down travel suffered and overall performance suffered for the sake of height. Fingers crossed that I'm doing it right this time around.
Lowering the rear will be trickier than lifting the front. It can definitely be done, but to my knowledge nobody makes a spring designed to lower these so you'd likely be exploring with running an OEM spring from a different rig (older gen 4Runner guys often run LC springs for a little lift out back, etc). I'm sure with some persistence it can be done, but it might take a few iterations to get it just how you want it!I would just like to get mine level by lowering the rear and don't mind a little stiffer ride or having to add air bags/shocks, when I need it to haul toys.
Curious if you've sold/installed any of the Dobinson non-adjustable internal resi (IMS) lifts and any feedback compared to these others you referenced. Also how do all these compare to Eibach Pro Truck 2/2R? I see those on your site also. Thanks!There are a few setups that will deliver significantly improved ride comfort versus stock.
Best overall for creamy ride comfort: Dobinsons MRR Coilovers. Toyota and Lexus vehicles typically have a decently high level of high speed compression damping which is what leads to the somewhat jittery ride many complain about. Dobinsons kits (and Old Man Emu for that matter) valve their stuff differently than Toyota/Lexus across the board, and to me, they feel significantly more refined. The MRR is not only the most refined of the bunch but also the most adjustable so you can dial it in even further than the out of the box settings. Even with significantly stiffer springs, it will ride smoother than stock.
I'm more sensitive to NVH than just about anybody I've met and I find Toyota's OEM dampers a little busy but have thoroughly enjoyed every OME and Dobinsons kit I've owned. I recently sold some MRR's to a member on the LC250 forum who had been through 3.5 setups so far; budget was no concern but he wanted to get it riding as well as humanly possible. He's finally 100% satisfied and said it rides better than his friend's stock Defender and he hadn't even touched the damping settings yet.
Great question! Yes, the Dobinsons IMS is probably the second most popular setup I sell and they are fantastic. In my opinion, the Dobinsons offers more versatility with multiple spring options, rebuildable/revalvable dampers, etc. The eibachs win on simplicity. They come with fully assembled fronts and use a simple threaded body so height adjustments are a breeze. They are also able to be purchased as just a front kit for leveling.Curious if you've sold/installed any of the Dobinson non-adjustable internal resi (IMS) lifts and any feedback compared to these others you referenced. Also how do all these compare to Eibach Pro Truck 2/2R? I see those on your site also. Thanks!
