Suspension question for the hive-mind
TacoPescado
Houston/Taos
I'm thinking about upgrading to MT64 coilovers and rear shocks on my 2025 OT but keeping the stock rear springs. I like the current rear height and don't plan to tow much or haul a lot of weight. Curious if anyone has experience doing this or would recommend different rear springs at stock 2025 OT height that would work better with the OME shocks. TIA...
why are you switching to MT64?
specifically, they have more travel which may or may not be an issue with your stock shocks. if the stocks won't stretch long enough you might lose a spring while driving. might need limiting straps and I assume you wouldn't want to go that route.
as for the front lift, get the $200 peak suspension 1" spacer. you'll get almost the same lift as the MT64 will give versus on OT while keeping oem ride quality.
having said all of this, I think ARB has a lower / lighter spring for "low" lifts with MT64.
    Votes: 11 84.6%
    Votes: 2 15.4%
