Transmission Clunk TSB L-SB-0042-25 (1 Viewer)
Don't get your hopes too high before you give it 1-2000 miles. Myself and other forum members had great experiences just after it was flashed, but it's come back after a few thousand miles.
Agreed. Our shifting issue is back. Will be bring it in for 10k service and having them look at it again.
There is no transmission fix - the flash helps for 1-2 weeks and then the jolts come back. I got my OT from my dealer yesterday. The dealer confirm that the flash is the only thing available for the transmission fix. Do we need to start a class action lawsuit?
There is no transmission fix - the flush helps for 1-2 weeks and then the jolts come back. I got my OT from my dealer yesterday. The dealer confirm that the flush is the only thing available for the transmission fix. Do we need to start a class action lawsuit?
I didn't get a fluid flush. I received a firmware flash as that's what the most recent TSB states is the solution. Have you inquired with your service advisor about that?
Me spels no good - I meant to say "flash". The dealership performed the firmware flash during my 10K mile service. It worked for two weeks, but the jolts came back—they aren't as violent as before, but they are way more frequent. I took it back for a set of other unfixed issues and the dealership contacted Lexus to confirm that there is no other fix but the firmware flash.
Sorry to hear. I've done a few hundred miles but have not had the same experience as you...yet.
I suspect that the dealer’s refusal to perform a software flash when I first raised the issue at the 5,000-mile service may have caused permanent transmission damage. At the time, I was unable to demonstrate the jolts or rough shifting during an 8 minute test drive with the mechanic because the issue occurred randomly and could not be reliably reproduced.
Truck is in for 10k so Im going to have them flash it and lube the U-joints/zerks etc to see if that helps. I’ve only had the “jolt” once or twice. By biggest issue is the lag on acceleration. I do agree the transmission could be smoother overall
We have alot of complaints with our GX on the lag on acceleration from stop. This is in addition to the clunk when downshift near a stop. We had the TSB fix done - it seemed to fix the downshift (not 100%) but the lag is still there. I am going to continue to push them on this when going in for the 5000k mile maintenance.
The acceleration lag is so annoying. Thats always been a huge gripe of mine since the GX is my daily. Ive only felt a downshift “clunk” once or twice thankfully knocks on wood
My LC 250 does this same thing, anyone know if Toyota has the same bulletin?
I told my dealer about this service bulletin when I took my 25 OT in for the 12 month service and they said they put me on a call list to have it done when it's available. It figures they don't know anything about it.
Longo told me it’s normal, said some are worse. I decided to called Ontario Lexus to set up an appointment. Receptionist doesn’t have a clue, but when I met my service advisor. He said we didn’t need the test drive as he is aware of that issue and did the software update and so far so good.
Pm me if you want to know which advisor I had. I can find it for you.
Ok, thanks. I'll probably take a print out of the service bulletin to the Lexus service advisor when I go back.
Had the TSB done and it did seem to help some (still have a noticeable thud 3-2 at ~14mph that never really went away). However, I now have what feels like a "shudder" when coming to a full stop under 3mph. It almost feels like the feeling on newer cars that have the auto engine shut-off at stop lights or if you've ever driven a manually transmission car and slip the clutch too much without giving it enough gas and the car kind of almost stalls/shakes. Seems to happen when the 3-2 thud happens but not really when it doesn't. Has anyone else experienced this kind of stutter?
Yes. This happens quite often for me if I slowly come to a stop. But if I go a little hard on the brakes, it usually doesn’t happen.
ok yeah, I noticed too if I come to a more abrupt stop or push harder on brakes it doesn't usually happen. Happens more if I slightly let off on the brakes/feather them a bit it'll give that little shudder that you can feel through the brake pedal.
Exactly!
Any long-term updates from those who performed the TSB by now? Thank you!
I took ours back for the 10k service and the clucking was back. The tech looked at it and told us it was normal. I told them it is doing the same thing it was doing before the TSB was implemented and they still did nothing but notate that we were having an issue.
