🛠️ Member Build Groovy Incognito OT+ (1 Viewer)
�Member Build
A few more pics of the rack. Added side molle panels with Rotopax mounts and Agency 6 shovel mount.
Trying something different. Went with KC Hilites new Platform One roof rack with 50” KC Titan light bar. It’s really unlike any other roof rack out there. Verdict is still out on usability. I’ll post some details on how this rack is different shortly.
That looks good. Any details on parts, install/wiring?
After ordering a few different sets, i settled on this one due to its shape and its ease to mount on the grill via double sided tape.
Amazon.com.
As for wiring, i ran each of the 4 wires down the grill lines (so wires arent exposed visually) to the bottom of the grill using small zip ties, then to the driver side to tie into one of my Aux switches. If your GX didnt come with aux switches, you can run to the passenger side and tap into the fuse box to an ignition source. Let me know if you have any other questions. Happy to help.
Amazon.com.
As for wiring, i ran each of the 4 wires down the grill lines (so wires arent exposed visually) to the bottom of the grill using small zip ties, then to the passenger side to tie into one of my Aux switches. If your GX didnt come with aux switches, you can run to the drivers side and tap into the fuse box to an ignition source. Let me know if you have any other questions. Happy to help.
Thanks! I have a 2026 OT so I have the aux switches. I’ll do some research and let you know.
Any photos you have would be helpful as I haven’t checked out the aux switch wiring nor location. Not planning to do this asap but something to look into. Appreciate it!
I'll take some pics and diagram how I ran the wires. As for the aux switches, it wasnt the easiest. This video I watched will help explain it. The problem is finding the right pins. The kit he shows in his video is no longer available on Amazon so I had to do some searching. I just did switches one and two for now. All my lighting are routed to my 6 spots on the Garmin Switch. I just didnt want to take up a spot on my Garmin for these raptor lights so i ran it to an aux switch.
Thanks - that will be helpful.
I did just stumble across this video not too long ago and watched it. Definitely seems like a pain.
