Does the compressor need a break in between filling up each tire? I know the simpler units you get at home depot ask not to run longer than 2-5minutes then giving the compressor a break.
I have not had any issues filling up 4 tires from 15psi to 35psi, even in high ambient temps using the oem compressor.Does the compressor need a break in between filling up each tire? I know the simpler units you get at home depot ask not to run longer than 2-5minutes then giving the compressor a break.
I am interested to know this too.Did anyone try this in a Premium Plus yet?
Not likely to fit as the compartment sizes are different with the 3rd row seating and might not have the extra connector thereDid anyone try this in a Premium Plus yet?
That was kind of what I was thinking. Dealerships I've talked to haven't been able to any kind of definite answer, but one said it wouldn't be a problem to install it. I was hoping the connector would be there and I could buy the interior trim piece and the compressor.Not likely to fit as the compartment sizes are different with the 3rd row seating and might not have the extra connector there
What year is your vehicle?I completed the install today. I couldn’t find a writeup online so I’ll give a quick one.
You will need to pull the rear cargo floor first, then remove the entire side plastic panel. Easily completed by removing lower seatbelt bolt and 3 10mm fasteners.
You will need to drill out the melted rivers on the cubby. Do not over drill as it will come through the front of the panel!
Once removed loosely and install the 3 provided screws to affix the bracket to the compressor. Interlace the nutserts on the right side and bolt the 3 fasteners through the body. The bracket is bolted to the inside of the jack cradle.
There is one plug that plugs into the panel and the rest go between the panel and the compressor.
I just ran into the most curious bug in the OEM compressor related to taking a break-Does the compressor need a break in between filling up each tire? I know the simpler units you get at home depot ask not to run longer than 2-5minutes then giving the compressor a break.
What part of the trunk is that compressor kit in?
The 2024 models didn't come with the air compressor. I bought the air compressor kit, which included the pouch and hose.What part of the trunk is that compressor kit in?
My '26 came with a micro-duffel that has all of the bits (outside the compressor) inside.What part of the trunk is that compressor kit in?
