Not in stock yet but here’s a device for those that are OCD. I personally don’t mind the slower speedometer as there are some benefits.
Seems to install behind the glovebox and easy to adjust to get the perfect calibration
www.lutzauto.com
Lexus GX550 (2024+) Speedometer Calibrator/Correction Device | Lutz Auto
The Lutz Auto Speedometer Calibrator is designed to calibrate your Lexus GX550 speedometer to display the correct speed, compensating for any modification that affects the speedometer calibration (ie. tire size). This will also update the rate of the odometer to match the corrected speed. Simple...
www.lutzauto.com
